Go to the device manager, then Human Interface Devices and then Surface Pen Settings. Click the Driver tab and check the driver version. If you are not using version 10.0.302.0, then you won't have the extra settings. However, if you are using that version, while you should have the extra settings, at some point you will start to encounter crashes/lockups and other weird behavior. The current "good" version is 4.0.112.1. but that version doesn't offer the extra settings.
I went about a day or so, then things got bad on my machine and I had to drop back to the 4.0.112.1 version.
