Well since remote desktop worked ok it's something with the app, the way it grabs the screen, or makes the connection. He should probably contact The SSyea that is VERY laggy, try another remote app like greyfox7 said... and if you find those other ones are laggy then something is def. wrong with your network
Ok but if Remote Desktop works fine then your network is ok. this in a Splashtop specific issue.Yep, have an active ticket with those guys tooThanks for the help and advice guys, I'm completely out of ideas....
Hope their support guys can help me out. Seems odd it's the same on 2 Surface 2's though, leading me to believe my network / computer config is at fault... but why does it work fine perfect on the Android phone? Brain hurts!!
