Trying to do a refresh! not enough room???
daniielrp
You can try to find an app for disk space that will graphically show you your C drive.
You can also manually look. Open This PC on your desktop. Go to C. Then right click on each folder and choose Properties. It will show you how large that folder is. Try to find the folder taking up all the room, the drill down and repeat for the subfolders until you fond it.
This normally won't tell you everything though (hidden files/system files etc.) so can give misreadings.
F
fastfed
C:\Windows.old
Empty the Recycle Bin and you are 75% of the way there....
nope, nothing in there
jnjroach
Administrator
Well there is another 2GB of space, so between the free space, the 3+GB and removing these you should be able to refresh....
F
fastfed
while I might be able to do a refresh, this is no longer the problem,.
The problem is.. WHERE IN THE WORLD IS ALL MY SPACE?? I can't have NO files, NO apps, NO NOTHING, and only have 5-6 gigs free..
come on, that's insane !!
