nipponham
BI is Background Infrastructure and it regulates background tasks for Windows apps. It sounds like you might have a bunch of apps set to display its status on your lock screen. This in itself should not disable hibernate but you should disable background tasks for apps which are not necessary, just in case. I did this and found that it saved a lot of battery drain during CS.
