malberttoo
Works as described. Hopefully more functions are coming.
Indeed, hopefully they will expand its usefulness as time goes by and the dust settles a little.
I open the app, it shows this picture for a couple of seconds and then crashes.
I have the original surface pro, which I guess isn't supported.
I do not have this problem anymore! Now it's working flawlessly. I'll just hover near the taskbar and it instantly appears. Wow. Anybody can confirm this? This is for sure no placebo, I was so pissed at this.Only annoying thing is getting this shitty taskbar up (when in auto-hide) with your finger/pen. Not working 90% of the time on first try.
I agree, it didn't get better with touch only. However a trick is now better working after the update, just drag from above the edge(and mark) till the edge and the taskbar will pop up everytime for me.Taskbar pops up with pen every time after installing hub, still does not respond predictably with touch.
If anyone has problems with pen recognition, just follow the steps mentioned in the app.
1. Open up Control Panel
2. Click on Hardware and Sound
3. Click on Devices and Printers
4. Click 3 times on the circle with an arrow at its end (refresh), to the left of the search bar on the top right corner of the window.
5. Restart the Surface Pen Hub app.
The app is disappointing, hopefully with time there will be added features which might make it worth downloading but as for now it is useless for me.
Thanks for creating the thread though, I would not have had any knowledge about it otherwise! Cheers for that!
/ Khalamus
