I have an important presentation. Client will be sitting on Sofa with my LG 47" monitor on the wall in front. I will be sitting on a table presenting stuff. I want my Surface Pro 2 desktop to be mirrored on the LG 47" screen.
- I have Surface Pro 2 running Windows 8.1 all updated via Windows update.
- Under Device Manager > Network Adapters >Marvell VASTAR 350N Wireless Network driver Ver = 14.69.24054.176 Date- 23/05/2014. Apparently it is the latest driver according to update driver online selection .
- Smart Share is enabled in settings of my LG Smart TV.
- If I right click on say an .avi file and choose "play to" I can select my LG TV and it plays the video on my LG TV. So I guess it proves that the hardware is ok on both sides?
Anyway so to mirror the desktop on to the LG smart TV. I tried going in to Charm bar > Devices > Connect to a different display > Add Wireless display > It searches and finds my LG Smart TV (called 666). It also says not windows certified.
Next step is where I get stuck. How the hell do I get it to project on my LG TV? Btw Project setting is set to DUPLICATE.
From researching it seems that the LG TV (666) should be showing on the right side of the attached image under Devices? What am I doing wrong?
Man why so complicated? Why is it not working? Please I need to sort it out soon.
