Ok to double check from those instructions:I mapped Onedrive the way someone posted instructions on and then from a posted video but it requires me to log in every time I reboot. I get an error every time I boot telling me it can't connect to all network drives. It wont connect until I double click on the drive and put in my credentials or hit ok if it remembers them.
I did check both boxes, not sure what "underperforming or suboptimal feature" means. Is there a way around it? Tried it on 3 different systems.Ok to double check from those instructions:
"Also, make sure you have the 2 boxes checked and you will be prompted to enter you Microsoft Account Info, when prompted make sure you Check the box to remember you credentials"
So if you DID check the box to remember your credentials then it might be an underperforming or suboptimal feature.
Underperforming - perform less well than expected.I did check both boxes, not sure what "underperforming or suboptimal feature" means. Is there a way around it? Tried it on 3 different systems.
lol ok so the literal definitions. ThanksUnderperforming - perform less well than expected.
Suboptimal - of less than the highest standard or quality.
Is there a way around it - not as far as I know.
Some might call that a bug but I don't want to be overly presumptuous.lol ok so the literal definitions. Thanks
Well that sucks, not only did they take place holders or whatever away from us now they are making this unavailable. Was really hoping for this work around, 64GB is not a lot to work with. Especially when you have 1TB of Onedrive space.It is happening to everyone that I know who are using this workaround... we're using old school SMB Networking Mapping and it looks like it attempting to authenticate prior to an active internet connection....
It will still work.... you just need to hit ok when the credentials screen appears .....Well that sucks, not only did they take place holders or whatever away from us now they are making this unavailable. Was really hoping for this work around, 64GB is not a lot to work with. Especially when you have 1TB of Onedrive space.
