Sorry, but do I understand this correctly? If you buy a Surface 3 you can't expect things to "just work"? Then you should have bought an iPad? What a load of *****
I've been having the 'touch' problem for well over a year. No updates make an improvement. The problem is I can't get any joy from the browser when using the pen, nor can I get any sign of life when using my finger. I use my bluetooth keyboard to scroll the page (either up or down) and it seems to fix the problem. I also have problems when trying to close a tab with the pen. No matter what I do or how hard I press, the tab won't close however when I ask the browser to close completely down at the task bar, voila, success. It is one of the reasons why I don't recommend the S3 to anyone.
I still don't agree with statements like these.Comments like this are reasons I don't recommend a manual transmission to anyone. "It should just work and cost me nothing. I shouldn't have to 'learn' how to use it. Who bothers learning how to use a product?"
Probably a glitch in the Matrix.Why did this topic just pop up as new in my Nextgen Reader?
First of all: the Surface line is not for people that choose the device with the least cost. People that go for the cheapest option take some Android tablet from a Chinese retailer. One can expect things to run less smooth there
Second: yes, it should just work. That doesn't mean people don't need to learn how to use products, but it does mean it should function properly!
The issues that I run into with my FOURTH Surface 3 within one year have nothing to do with me not knowing how to work with Windows, a tablet, a Surface etc.
The same goes for people buying a Surface Pro 4, Surface Book. Some issues should not occur and are completely separate from people's knowledge
I don't get your point... You always end up having to figure out a way to make it function properly or end up finding out it will be a known issue with the device? So none of your devices ever worked properly?! I would be really worried...
