Nuspieds
Yes, follow the Acronis steps to create your boot medium (USB stick or CD). Then you can boot from it to test the restore.I have acronis should I setup a USB stick and boot that to run it, as normal. Then remove and insert the backup USB stick, follow the prompts.
You stated you have Acronis, but that's just the vendor's name, so I'm not sure if you meant that you also have True Image. Regardless, they make several backup software products and whatever product you are using from them, you definitely need to test and confirm that the product does indeed create a Surface Pro-bootable medium.
