wynand32
I'll add that mine didn't do this once yesterday, after doing it a couple of times on Saturday. So it's obviously not a consistent problem even on given machines. Which is just a data point--it doesn't make it any better.
My issues:
- Is there a lot number associated with those whose devices exhibit none of the above (running stock) ?
The 4-digit lot number is on the box label. E.g., 1542 means the 42nd week of 2015, hopefully someone with a great unit will report the lot number.
When that happens, the panel has dropped off the device list. Press Win+P, wait two seconds, then press Win+P a second time. This will throw the screen to a "projector", then bring the focus back to the local screen. The process of changing focus between screen forces a re-detection of the monitors available for connection and the internal panel will then be re-activated.
It's almost certainly a driver issue and, since I found this fix nearly 2 months ago (and posted it on reddit), I'm surprised MS hasn't fixed this bug already. It demonstrates that they are either horribly understaffed or entirely apathetic to the problems on their flagship device.
My issues:
Have you or anyone else ever had an issue with the sound driver?
Sometimes on my SPi7 my sound will stop working and i will have a red X showing on the sound icon. I have to reboot or enable / disable in device manager to get it working again.
If it is any consolation the late December Beta Video Driver fixes 99% of the power management issues mine wakes from sleep and hibernation.
That is odd, my only drained 13% overnight.....Okay, so, I installed the beta drivers, and mine still doesn't seem to sleep. Put it to "sleep" and two hours later it went from 54% remaining to 11%. And that was following a reboot with nothing specifically started.
Grrrr.
I have S0ix for 240 minutes then hibernate....I'll have to make sure the beta driver took. And yours is sleeping and not hibernating, correct? Don't mean to be obtuse, it's just this is really bugging me.
