USB 3.0 hub on sp3?
I purchased a 4 USB hub from microcenter for 2.99 and it works absolutely fine. It's compact.
The only thing I would recommend is getting a hub that has a lengthy cable or else it will be hanging down from the sp3 USB port...
Can anyone recommend a USB 3 hub they are using for connecting the sp3 with a keyboard, mouse, monitor?
I am using a hub right now with the ethernet adapter, keyboard and mouse and I am getting some ports going dark here and there. I think I need something a little better. It's just the hub built into the dell ultrasharp monitor.
Thanks!
I was looking at this one.
Amazon.com: [3*USB 3.0 + 1*Gigabit Ethernet Adapter] Inateck 3 Ports USB 3.0 Bus-Powered Hub with RJ45 10/100/1000 Gigabit Ethernet Converter LAN Wired Network Adapter for Laptops, Ultrabooks and Tablet PCs with USB Ports, Compatible with Windows XP/
