Trident Cyclops Case
I have being using the Cyclops case for months now. No problem with heat and fully compatible with the touch cover.
It has no problem to accommodate a tempered glass screen protector of 0.33cm thick. I emailed UAG before i placed my order for a cyclops and UAG rep could not give a confirmation whether the UAG could accommodate the MIME ghost glass without lifting it at the edge. Trident rep said it should not pose a problem.
I love the way the casing wrap the entire sp3 except the screen and easier for me to grip it.
The photos i uploaded show the use of the sp3 kickstand and the other thing is that this is the only casing that allows the access to the micro-SD card slot without taking the sp3 out from the casing. I do not use the dock so this casing is just right for me.
The Cyclops case looks hella ugly and cheap looking. Even though the UAG isn't much better, it looks more rugged.
If you're the type of person that MUST have a case on every device you own, then you won't really be too too happy with the SP3. For all of the different scenarios, there's always SOME quirk that a case is just going to be too impractical when it comes to the SP3...
I typically swear by cases for all my expensive devices, but whilst using my SP3 for docking, work, typing, etc. a case just seems to muck things up. Best I've managed to do is a scratch guard that provides minimal scratch protection. Either the case wont let u dock/use the stock kickstand/covers the cooling vents/bulky/doesnt let u use stock keyboard/DOES or only lets u use the stock keyboard/doesnt provide screen protection/i could go on and on... There's just too many dealbreakers, simply bc the way in which its designed.
Now, are there die-harders that at-all-costs MUST HAVE a case? Of course, I am just not one of them =)
