Jesse San Nicolas
I just completed a test using two identical i5-256GB SP3's (both my fiancee's and mine) side by side. One with the Urban Armor case on and one bare naked
For quality control, these settings were identical on each machine.
1st screenshot is UAG SP3.
2nd screenshot is naked SP3.
Both UAG kickstand and SP3 kickstand were set at 40 degree angles.
5 minute mark - Systems idle before test
10 minute mark - Prime95 has been running for exactly 3 minutes
15 minute mark - Prime95 has been running for exactly 8 minutes
20 minute mark - Prime95 has been shutdown at 17 minute mark and System idle for 3 minutes
28 minute mark - Internet Explorer open with 2 tabs running*
30 minute mark - Final results*
CONCLUSION: The Urban Armor Gear SP3, while running slightly warmer than it's naked counterpart, actually has a higher CPU average.... Lol, just kidding.... Well, it does actually.
What this test really shows is that while the case does make the SP3 run 10-15 degrees warmer, this is only done when using the CPU's at 100% max for an extended time. Bear in mind this is not typical or even close to what an average consumer would use their 3 for. It also shows that both systems start to throttle at 91 degrees exactly.
What it also shows is that doing basic web browsing and the sorts, makes no actually difference with or without this UAG case as the difference is negligible.
It also seems to show that regardless of the UAG case, your SP3 will perform exactly the same, even if doing CPU intensive tasks, such as video editing, or graphic design. The firmware in the SP3 seems to throttle the CPU perfectly, without taking a hit in performance.
What really shocks me is how the SP3 with the UAG case on has a higher CPU average of almost 100MHz at the 15 minute mark, while it is running 10-15 degrees warmer than the naked SP3.
LAST WORDS: It's very hard to believe, and very weird, yet exhilarating to know that the UAG actually improves CPU performance over a naked SP3 under intensive workloads, albeit running much warmer. In any case, the UAG case removes all traces of heat being transferred to the end user. Maybe they should advertise that on the packaging
Oh, and my Microsoft type cover keyboard is not flimsy one bit. It's actually much sturdier than those folio cases sold on Amazon. I would also have no problem throwing the SP3 with the UAG case and type cover on in a book bag one bit, and I'm not rough with my devices at all. That's how solid and comfortable I feel this UAG case and type cover would protect my SP3.
Remember CPU's are designed to take the heat, and either way, the SP3 throttles at 91 degrees with or without a case. What they aren't designed for is to be DROPPED, and almost every device get's dropped at some point in it's short-lived life, no matter how careful you are. You choose.
- Advanced system settings - Performance - Let windows decide - Best performance -Programs - Virtual Memory 400MB-2048MB
- Identical programs running in Systray
- Windows Defender on
- HWiNFO64 to monitor temps
- Prime95 set to Torture Test- Small FFTs-Maximum Heat
- Cold start - Both systems shutdown 1 hour prior to testing so as not to taint results with residual heat
- 5 minute mark - Systems idle before test
- 10 minute mark - Prime95 has been running for exactly 3 minutes
- 15 minute mark - Prime95 has been running for exactly 8 minutes
- 20 minute mark - Prime95 has been shutdown at 17 minute mark and System idle for 3 minutes
- 28 minute mark - Internet Explorer open with 2 tabs running*
- 30 minute mark - Final results*
