Travel Case for Surface Pro 3
If you want an outstanding case, get the Brenthaven Collins Sleeve Plus DFS (Designed for Surface). It just came on the market and I just received mine yesterday. It's pricey ($50) but you can find coupon codes for it that will bring it down. But it offers the best protection, has TWO compartments for accessories (including a magnetic flap that holds the pen, and is very well built. I HIGHLY recommend this case. Check it out here:
http://www.brenthaven.com/collins-sleeve-plus-microsoft-surface-pro-3
So I decided to keep this:
http://www.amazon.com/Booq-Hardcase-11-Inch-Chromebook-VHCB11-BLR/dp/B00BXO6NS0/ref=sr_1_5?ie=UTF8&qid=1405465266&sr=8-5&keywords=booq viper case
I had to figure a way to fit it in, slide in the SP3 without the keyboard and it works well. The pen has to lay on the side.
20140717_094915-1.jpg 20140717_094929.jpg 20140717_094940.jpg 20140717_094956.jpg 20140717_095007.jpg
I got this one from ebay, they make to order for any device. There are different designs available too.
I got this one as well. Looks nicer than the one I posted earlier and cheap! I have prime so why not? I might also get the other one I linked. Case inside of case! (Inceptionesque)
I got this too. I still thought it was kinda cheap looking.
Then again, it IS cheap.
I found a thread relating to the old size, but I think a new topic is needed for Pro 3 cases.
I'm looking for some sort of sleeve for my Pro 3. I don't want anything bulky with it's own kickstand and whatever, I just want something to keep it in when it's in my bag, and take it out when in use. Any suggestions?
Resurrecting this topic. My ideal case would replace my full size laptop case, but have room for accessories beyond just a power adapter (video/usb cables, power cell, and minimal documents). This HP Mini Messenger is as close as I've come to what may meet my needs. It measures 11 x 14 x 3 inches compared to my current full size case at 13 x 16 x 4. Only a difference of 2 inches in height and width, and 1 inch in depth, but everything else I've seen is way smaller or way bigger. Decisions, decisions.
http://www.amazon.com/dp/B002UZLFI4...TF8&colid=2D8WWF2WGL7CK&coliid=I3VVCK6ILQMK6Z
