graye
Here is another shot while installing software, but running off the battery. I am using WiFi and nothing plugged into the USB port. The previous example had the charger plugged in and both a USB mouse and USB Ethernet adapter plugged in.
Same pattern as before, but significantly lower temperatures (113F vs. 96.8F)
Note: The heat at spot 4 was probably left over from where I was resting my hand
