Well in this thread at least two of us now can replicate the issue as much as we want without any SD card plugged in.
But if you
really suspect the Realtek SD card reader drivers, why don't you just remove them as I mentioned above? I did that this morning, and as expected, the only thing that happened is that I lost the SD card specific icon in "My Computer"... but drive D: is still there, and the files are still there.
Seriously, the SD card is a EL-CHEAPO USB card reader, with the only difference that it is soldered to the motherboard! From the operating system point of view it is exactly as any other USB pendrive! The ONLY thing the Realtek SD card reader driver does is put a nicer icon in explorer!
That said.
I have been bitten by so many weird Windows bugs that I wouldn't discard the chance that even such a simple icon-changing driver would cause problems in a completely unrelated area. (e.g. such as that one USB Tablet driver that caused the icons in the notification area to become black and white back in Windows 2k days).
If you really believe the SD card reader is related, I suggest you remove the Realtek card reader driver using the above instructions.
But in my opinion, it's not the cause, and it
shouldn't be the cause.
(BTW, I haven't experienced "The Issue" ever since I removed the driver this morning, but it's been two boots only so far. At this point I'm hoping it fails soon, otherwise I will have to backpedal on my words
EDIT: Ok, I got the 30% CPU just now. To recap,
removing the Realtek SD card reader drivers has no effect on the problem here.
