Nuspieds
Like any other product, if it doesn't work out for you in your real-life usage scenarios, then you did the right thing by returning it. Specs and reviews are one thing; putting a product into real-life use is another.
For me, however, I did lots of research and prepared myself way in advance. As an example, I knew the Surface Pro didn't have an Ethernet port and I'm the type of person who always prefers wired over wireless, so I researched and found an Ethernet/USB dongle. I also did the same for a fingerprint reader.
I successfully replaced my ThinkPad W700 and its docking station with my Surface Pro. The only outstanding compromise is the multi-monitor display support. With my ThinkPad, I had 2 external monitors, both running 2560x1600; one was VGA-port attached and the other was DVI-port attached.
The Surface Pro only has one video output and that's the mini DisplayPort. So right now I am stuck using just one additional external monitor. I'm definitely not interested in video via USB (through my research I found out that this cable also exists) because that would just eat up too much of my USB bandwidth. But I know this situation is temporary; I'll soon be buying a DisplayPort v1.2 monitor, which will allow me to daisy-chain to another DisplayPort monitor.
In my case, I have the USB, DisplayPort and audio jacks all plugged. Is that "Frankenstein-ish?" If so, well, then, what do you think my ThinkPad docking station looked like?!
My point is that I love my Surface Pro; it is a beautiful, elegant machine that has completely replace my full-blow laptop. However, were it not for multi-port USB hubs, I certainly would not have been successful with the transition. But since that is not the case, I definitely consider the Surface Pro a success.
