Here are some suggestions for reducing eye strain
1. If you use the SPro in your office mostly, then try connecting to a larger external monitor, the monitor should be placed at eye level, ie: you should be looking straight ahead at the monitor rather than bending over it.
2. If possible use an external keyboard/mouse, this must be placed just above your lap level, so basically your hands will be resting comfortably on the sides while using the keyboard.
3. Ensure the chair you sit on, has a straight back, browse through the internet, there are many medical sites that provide tips on selecting the right chair.
4. You may also have to place a low intensity light on the backside of the monitor this reduces eye strain especially if your office is dark.
The Spro is mostly designed for mobility rather than office use, a laptop may be slightly better in this respect but even then some basic changes as suggested above would be required.
Eye strain and headache associated with laptops and electronic devices should not be ignored, as this can lead to chronic issues. There are many sites in the internet which suggest remedies for improving these conditions
thanks
a
thanks
a
