Surface Pro 4 with Dell 25" or 27" monitor?
Just bought the 4k P2715Q. Tested it (together with the USB hub) - that's a great, great monitor. That's what I was searching for in terms of level of detail. The 1440p are not even close to what the Surface Pro 4 provides. However, the 4k is and I am obviously now so spoiled because of the Pro 4 and my iPhone 6 that I cannot look at any other thing...
To all of you who have P2715Q - have you done something special to configure / calibrate it - any drivers, tools, whatever?
Just bought the screen. Have you noticed any issues with your Mini Display Port (Surface) to Display Port (the cable that's in the package)? When I plug it into the Surface I am sometimes losing my Wi-Fi (network) connection. I have to move or push the cable harder and then magically it starts working. Same if I remove the cable - the Wi-Fi is back immediately?
Good thread. Thanks. I am looking at the Dell 34" ultrawide and these specs seem similar with scaling and res
I use the Surface dock and have not experienced that problem.
Porn looks great at 4k with the SP4 PB287Q at 60hz
highly recommend SP3 and SP4 people get 4k monitors - almost as good an experience as the 5k iMac ;)
