Surface Pro 4 with Dell 25" or 27" monitor?
I think they are not really that blurry. It just stands next to my iMac 5K. The direct comparison makes the fonts look bad I think.
SP4 dock @ 60 Hz.
Hey Matt, what's the refresh rate / maximum resolution you can get if you directly connect it to the Surface Pro 4? I would appreciate it if you let me know cause I just saw the U2715H and it's like a step back from the Surface screen - it's just not crisp enough. Probably I also need to go to 4K and your screen looks like the proper choice now?
3840x2160.
