Mark Carter
- Joined
- Sep 9, 2017
- Messages
- 4
- Points
- 1
- My Device
- SPro4
Recently I noticed that the glass screen on my Surface Pro 4 had lifted out of the bottom quadrant of its case. I had been working outside on a hot day (90 degrees F). The side of the screen facing the case seemed to have residual glue on it. I took the computer into a cooler environment and placed a stack of books on it to try and reseal it, to no avail.
Microsoft service was no help as my warranty expired.
It is not affecting the function of the system but it opens the door for reduced cooling and foreign matter intrusion. I have looked for an adhesive or epoxy to seal it but I am concerned that I could compound the problem. Are there any ideas how I might fix this problem?
