Solved Surface Pro 3 taking forever to boot during restart
Lobo
Surface Book
Hi guys,
I got a new SP3 recently and was quite amazed in the beginning.
Unfortunately, soon I started to enjoy the typical Windows problems which drove me away from the platform a long while ago.
All of a sudden, my device decided to take forever for a simple restart. What used to take mere seconds led me to using the Vol-up-Power-Btn-Combo after a while, because I thought it froze on me.
Then I noticed, that it will actually start, but it takes about 4-5 minutes to arrive at the login screen.
I did a restore once, which only led to a short period of relief.
All Updates installed, no anti-virus other than MSE, no tune-up tools installed.
Automatic Repair didn't help, neither Dism nor sfc showed any errors.
I installed the Windows Assessment and Deployment Kit and ran the Performance Recorder, but the Analyzer didn't give me a clue either.
Finally, the Event Viewer leaves me with a simple info: Windows is not functioning anymore. Of course, there isn't any useful follow-up hint and in the end, Windows boots just fine.
Any feedback is greatly appreciated.
Hi guys,
Hi Lobo.
If you've already done a restore procedure and returned it to factory state, and you're still having the issue, it is probably a hardware problem. In your case maybe the SSD isn't quite right.
I'd exchange it.
Ouch, that doesn't bode well.
Maybe there's somebody around who could run my WPR logs through the analyzer and see if they can make any sense of it as a last resort?
You might download & run the free version of Malwarebytes. I have fixed a lot of slow systems running Malwarebytes. It can find a lot of crud that slips past a lot of antivirus software. Other than that & a factory refresh, I would take it back to the store & get it exchanged.
Thanks a lot for the feedback guys! In the end, I had to do a factory refresh, doing reboots after all major installations. So far, so good. I hope it'll stay that way. :)
I thought this is what you said you did in your original post. You must have meant refresh?
Sorry Michael, y'all caught me on ma sloooow day. ;)
Of course, I didn't do a simple refresh (yes, did it before but it wouldn't help), I rather put the whole thing out of its misery and did a complete wipe including reset to factory state.
Still holding up btw – keep on pushing them thumbs, would ya? :D
Great, glad it worked out for ya and your SP3 and running trouble free... always sucks when our expensive toy don't work right... ;)
