Here are my thoughts. I have the financial means to buy the Surface Pro 3, but I am keeping my Surface Pro 2 at least until Broadwell, and probably even longer than that.
What I don't like:
- It's too large for me and this is a deal breaker
I do like the new screen, especially the height (I am a programmer and I need to see lines of code), but the bezels are larger than what I imagined and the comparative pictures show that the SP3 is quite a bit larger than the SP2 (28mm more height and 17mm more width). I was hoping that they would keep almost the same dimensions as the SP2 but with thin bezels and larger screen. Did not happen. For example, I do some car tuning and the SP2 is great to handle inside a car. The SP3 will be just too big.
- The $1300 model has the same internals as the SP2 (4300U processor, 8GB RAM, 256 GB SSD). I never use the pen, so I really don't care about the digitizer tech change. Wi-Fi + Bluetooth fiasco is probably fixed but this is minor for me, I use 5GHz often.
However, I do like the fact that they didn't wait until Intel Broadwell to launch it (although there will probably be a Broadwell refresh in about 6 months from now). I hate when Apple and other manufacturers are moving just too slow - look at the ancient MacBook Air with 1366x768 resolution in 2014. Dell had something possibly great with their XPS 11, but they blew up the keyboard. If you have something ready, just launch it ! I think that it was the new CEO Satya Nadella that had a role in this early launch.
- I really don't care about the better thickness and weight (I do bodybuilding
- The keyboard is really disappointing in the fact that they did not separate the function keys from the editing keys (PgUp/PgDown/Home/End/Delete) despite having a lot more real estate to work with. For a programmer, this is one of the most annoying things in the Type Cover. The function keys are used a lot, and also the paging keys. They should have released at least an alternative Type Cover with separated keys and smaller trackpad (which I never use).
- No second USB port and I really needed it (I really didn't expect this. If they want it to replace a laptop, shouldn't they include a second USB port ?)
- The new stand is ok but I couldn't use such an expensive tablet without a case, and my favorite case has a stand of it's own with multiple angles, I never used the SP2 stand.
So basically...the SP3 doesn't fit my needs. I need to get used to the thought of a significantly larger device first.
But I do hope that it will sell in large numbers, it will only benefit competition from Dell/HP/Lenovo/Asus/Acer which right now are really clueless, all their thin hybrids use the Y-series lower performing processor and have lower build quality (to be honest, they need to make a profit from their hardware while Microsoft can afford to lose on hardware while gaining from services).
