Thanks jnjroach, demandarin and everyone else for the tidbits of info.
Some questions:
- The SP2 kept the original SP chassis but moved to next-gen Intel Haswell innards for cooler operation and longer battery life. Whereas the SP3 offers the same Haswell but in a brand new design. Following this tick-tock cadence just like with Apple (perhaps with an accelerated development cycle), will the SP4 keep the same SP3 body but with a jump to Intel Broadwell and Windows 9 (assuming both will coincide late 2014 / early 2015)? If we do buy all new accessories for the SP3, will they remain viable for the SP4?
- How come the
N-Trig Bluetooth 4.0 pen is stated to use both an AAA
and two coin cell batteries? How long's the estimated battery life? Reviewers claim it feels more like writing on paper, does that just mean it uses a more rubbery tip compared to the SP2 pen's smoother plastic tip? Will the N-Trig pen work out of the box (with the built-in Windows driver) for all programs including Adobe Photoshop, or is there an N-Trig custom driver? Lastly does the N-Trig tech support hovering, and does it also suffer pointer offset around corners and edges of the screen?
- The SP3 also uses the Haswell U family, with the same 42Wh battery (and in fact the bigger screen and i7-4650U CPU variant may consume extra power). So how come it uses a
smaller 36W power supply compared to the SP2's 48W power supply (both have a USB charging port). Will the SP3 take a lot longer than 2-3 hours to charge? And why the redesigned power connector, is it just to avoid scratching the bezel?
- Does the new Type Cover actually have bigger keys and more generous spacing, or does it use the same keyboard deck as the older covers? And is the new touchpad actually any deeper, or is it simply
wider? The SP3 itself is over 1 inch taller (and almost 3/4 inch wider) than the SP2, but it looks like the new Type Cover loses space for the magnetic strip area (which adheres to the SP3 bezel), such that the touchpad on the palmrest couldn't really be made much deeper?
- Where's the MicroSD slot on the SP3? Can't seem to find it on the pics and videos.
P.S. Looks like the new
Surface Ethernet Adapter is now GigE
