TeknoBlast
I need to double check my kickstand, but I dont think mine has any wear and tear like that. Are you placing your Surface on a rock-like table?
I just bought my Surface maybe a week or two ago and now just realized mine is beginning to scratch, very lightly, around the case, and looked up the problem and found out it is a common problem. I can only see it becoming a bigger issue like the finish chipping away like with others, and I was thinking of possibly putting on a layer of truck bed lining seeing how its invulnerable to almost any kind of scratch or hazard damage. I've seen it done with laptops before. Does anyone know if this would be an ok route to go with the casing?
