opening lid does not activate screen
diversion
Hi there,
i am using a surface pro 4 with a ms type cover!
Whenever i close the lid the screen of the surface goes black (hibernate is disable though).
But when i open the lid again after 30 seconds the screen turns on ONLY if i press a button on the type cover.
- is this an intended behavior?
I have also reset the power settings to default schemes but this did not change anything.
firmware & windows 10 are both updated to latest version.
I would be very happy for any input.
Thank you.
I also have to mash the type cover a bit before it'll be recognised and the machine will then wake up from sleep.
