Need help with pen
Ryukote
Hi,
I have noticed that when I place pen close to the screen that cursor shows up and it is following my pen even tho I am not touching the screen with the pen. Is it possible to disable this since it is weird to draw like that. I want only for pen to draw when I actually touch the screen with it.
And one more question. I have noticed an option to disable hand touch while using the pen but if I First place my hand on the screen and then pen, screen recognizes my hand and draw weird lines on that position like I wanted to draw with my hand which I don't want to. Is it possible to also disable that without disabling the touch?
Wevenhuis
If I'm not mistaken you can find the "off switch" for the cursor and palm rejection in the pen settings in the settings app.
Staff online
Members online
