M minhsuke New Member Nov 12, 2015 #1 My surface pro 4 fails "display driver stopped responding and has recovered" How to fix it?
J jbowden Member Nov 12, 2015 #2 its a faulty driver. Until a new driver with a fix is implemented there is not a solution.
OP M minhsuke New Member Nov 12, 2015 #3 I feel the problem that makes my surface pro 4 occasionally does not work and must be restarted
leeshor Well-Known Member Nov 12, 2015 #4 If you are using Edge, stop, at least until you get the next big update. which should be today. Being that there are dozens of threads with this same issue this one is closed.
