I had a SANDISK and it kept giving me problems.
I switched to Samsung....and now I am a happy camper....no issues whatsoever.
I wonder how you tell the difference between the real thing and a Chinese knockoff since they likely both come from China.Well I hope I don't speak too soon, but I just purchased a Samsung 64GB as well... so far almost 2 days and NO issues.
I think SanDisk 128GB's either have an issue, or there's Chinese knockoffs in the market.
I knew about this type of tool but it only tells you if the device works or not, that doesn't really determine fake or real.You can use this tool to help you make the determination of status:
http://www.pendriveapps.com/test-for-fake-usb-flash-drives-h2testw/
Sorry to be the bearer of bad news, but most likely it's a Surface Pro 3 hardware issue. I went through 5 Surface Pro 3's before I finally got one that was not defective in someway. Out of the 5, 2 of them had the SDXC card unmounting on a regular basics (same issue pull out or reboot would bring it back for a little while), 1 wasn't tested or kept for very long, and 2 of them worked fine and never un-mounted. Microsoft knows of this issue, but is not fessing up.
I think you're over reacting... I tried A Samsung and it's working flawlessly. I'm not saying that there's not a possible issue with SDXC hardware driver, but it appears SanDisk has major compatibility issues with their Micro SDXC or the product is failing at a very high rate. Before I'd go through the hassle of returning my SP3, I'd be sure to try anything but a SanDisk
