Max external display resolution for Surface Book 1?
elee532
Can the surface Book 1 support an external display at 5120 x 1440 resolution? I would not need the internal display at the same time.
Also, same question for the Surface Book 2.
Thank you!
With a Surface Dock, two external 4K displays can be used. I don’t know about direct connection.
I may be off base here, but I'm gonna assume that since 5120x1440=7,372,800 is less than 4096x2160=8,847,360 then it oughta handle it. Thanks!
