how to upate without using MS Store ??
blind
My version:
Windows RT 8.1 Preview
Evaluation copy Build 9431
I dont know why i cant dowload directly from ms store
does anyone knows another way to update to 8.1 ??
there is no update avaiable on windows update
So the instructions at the end when you click on "ms-windows-store:WindowsUpgrade" from IE doesn't work?
You can reset to factor 8.0, patch before 8.1, and then update 8.1 with the store.
