kundas1
sorry but I disagree with you, it's is sooo easy to search for what the OP was particularly asking help with, it's not hard nor unique at all! but you do make a point where this is the best place to find something that isn't in the "norm" like my problem which I couldn't go to youtube nore anywhere else, as it was a unique problem. Hence why I posted here asking for assistance. Asking what are the differences between the 2 Surfaces (and asking for graphs?) is not OUR JOB but is easy to look up, goto MS site for graphs and specs as that's where they have it posted or if you wanna SEE how they compare then you goto youtube (again not difficult) sorry but that is how I see it. now if your asking what our opinions of the device and if we like it then I can see coming here and asking because this is a good place to ask, since we all own one lol
to the OP my opinion (which probably worth 0) you'd be better off with a Surface 1 as you said you didn't have much money and it has Office on there, if you need some heavy word doc or excel editing that you can't do on the Surface, then you can install splashtop and connect to your main computer AT HOME/WORK and use whatever Office you have installed on there which will work fully... with splashtop you can use any legacy app that is on your computer. if your not familiar with splashtop google it and they will tell you everything you need to know, or even youtube can demonstrate how it works.
