hello
I am really enjoying my Surface pro, however I am encountering an issue when utilising an external display via the USB3 connection.
I am utilising a Toshiba Dynadock with it a Asus VH-23h monitor (DVI) and I extend the display over the Surface Pro and the external monitor... All good, however when I am typing quickly, cutting and pasting, or as it seems mostly, belting away in excel, the external screen goes out of focus....I.e blurry for a few seconds - some time longer. Once the calculation is done or I move from the cell with formula in it the monitor comes back into focus... I have also noticed this when I scroll or move back and forth quickly in the spread sheet......its very annoying!
Anyway, I tried the monitor through USB display adapter...and the same thing... I guess the next step is to try the min display port?
Anyway, its really annoying me on what should be a great set up with the USB 3 hub. in which I was about to go and get a second monitor..
Any thoughts on this, is any one having similar issues? I am slightly worried there is an issue with hardware like the CPU graphics. Appreciate any feedback.
Thanks
Thanks
