Don't get me wrong but I don't really understand your reaction?
I know about the warranty, thats why I quoted the text from Microsoft. Everything appears to be the standard warranty if you look to the two dates. It is definitely not the complete warranty. I was just asking and wondering if there might be another warranty option that wasn't listed on the MS site. But I already know now there isn't.
And yes I knop these units are "unrepairable", at least not through standard methods. There are roughly only two main parts in this SP3. The mainboard including soldered CPU, memory, etc. and a detachable SSD. And these parts are only reachable by removing the screen what is almost not removable without breaking it. Still, it is still possible to do it, but very very very difficult. So this makes it repairable
Despite knowing better and my good sense saying I shouldn't buy it. I just bought this puppy
The water damage must be quite severe. The water entered the top left part through the ventilation and the power connection on the right has corrosion. So the whole device has been swimming in the water. But I was still to curious about it so I bought it anyway.
It does start when powered and I get the screen I showed a few posts back. This are the things I think are faulty about the device:
- SSD doesn't work. See image below. It only shows my USB drive when I start the recovery usb. I also can't do a factory reset because he can't find the drive.
- Screen is affected. Touch does work but you can also see on the image below there are all kind of spots on it. It does work however. Haven't tried the pen interface because I don't have a pen yet.
- Battery doesn't charge. At least I think, I just had the device plugged into the power for a few minutes and it doesn't start without being powered. I don't want to try to charge it yet, I first want to figure some stuff out before I charge it. Maybe I want to opened, and if I do, I don't want it to be charged.
This is my first plan of approach. I'm going to install Windows 10 to a microsd card (or usb) and boot the device from there and see what it does. Then I can get more information about the hardware status.
