Thank you, thank you, thank you, thank you for the Logitech referral!!!!!
First I had the Wedge, then switched to the Apple Magic Mouse. I loved the Magic Mouse, but it required somewhat of a hack go get it to work in Windows. Still, I found it to be better than the Wedge.
With the Magic Mouse, I had the same--if not worse--Bluetooth connectivity issues with the SP (i.e., it would drop intermittently) as I did with the Wedge. But the Magic Mouse does devour batteries, so I went with the Mobee charger and its rechargeable battery. After about 6 months, I found that the battery wasn't holding the charge as it used to, though, so I had to get new ones recently.
Then I stumbled upon this thread, thank goodness! I said to myself that I'd give it a try, because I do like Logitech products. I was definitely worried about size, so I ordered just one.
It definitely is more compact than the Magic Mouse. Moreover, I was impressed with the built-in charge port. With the Mobee charger, although you gain the ability to re-charge the battery, you now need to carry an extra device (the charger) to charge the batteries. Yes, it is slim, but it still takes up room.
With the Logitech T630, the mouse has the charger port built into it on the bottom. So, slimmer than the Magic Mouse and no need for the Mobee charger plate...absolutely fantastic!!!
After one day of actual use, I uninstalled all my Magic Mouse drivers and ordered two more Logitech T630s to replace the other two Magic Mice at home.
I know it is not McDonald's, but I'm lovin' it!
