mikecox
- Joined
- Dec 19, 2016
- Messages
- 86
- Points
- 8
- My Device
- Surface Book
My current monitor has a resolution of 1920 x 1080 which isn't even close to what my Surface is. I want to replace it with one that matches the Surface, but it doesn't look like exact match is possible.
I do a lot of photo editing and Adobe software and I usually stay on the Surface for detail edits, but I have to adjust a lot of settings to get menus and panels to be readable. Then when I move the program to the ext monitor I have the change them back, because they are so large. So I can drag my photo editors between monitors without a hassle.
What is my best option? Could I go with an Ultra HD; like 2840 x2160, or this that overkill?
