At what temp does your fan kick in?
My fan comes on if I'm syncing files with OneDrive. I also tried BlueStacks, but the fan came on almost the entire time I ran it. So I ended up unistalling it.
What are you all using to check the temperature? I'd like to be able to check mine as well.
I've been using Speccy.
Thanks laestrella and jtuck82 for the recommended apps.
