Well everything was going fine for awhile....then this 9/9 firmware update comes down the pike for the 3rd time....1st time installs successfully....2nd time fails....now 3rd time installs successfully...I think maybe it came again because I had the latest intel graphics drivers installed....but anyway after this update and after a shut down and restart the pen cannot write properly...seems like it is miscalibrated....the lines are much darker when trying to write..like the pressure was doubled and it even writes when the pen is not touching the screen....I looked in settings but haven't found a way yet to calibrate the pen...just wondered if anyone else has or had this problem and what did you do to resolve it? thanks
OK found the pen calibration tool and that seems to have fixed the pen issue...maybe could help someone else who has the same issue...
