MickeyLittle
Well I'm finally giving up on hoping that I'll be able to fix the 1 and only issue that I continue to have with my SP2 4300u and that is it's dark to bright screen on wakeup issue. This only occurs on battery power and the unit must be asleep for several minutes before this happens. But under these circumstances when you wake it up the screen is dark and gradually brightens over the next 5-6 seconds to the brightness level that I have it set at. This varies throughout the day as sometimes it awakens lighter than other times. But when it is plugged in to a power source the screen wakes up consistently at the brightness level it is set to run at. Auto brightness is off.
Customer Service told me that I would be getting a refurb but that since my serial number shows a 128 gb 4300u then that is what I'll be getting back in return and that I have 15 days to get it back to them after I receive the replacement. So I'm not concerned about getting a refurb as long as it is in great physical condition and fixes my problem without giving me any new problems...
