First thing I noticed when I performed my ocd check. Just tried the above solution and it seemed to have worked. Thanks! Now need a way to get rid of backlight bleed (not bad enough to return, but would love a fix)..
You should have given in to your Medical natural instincts and applied the "Amelioration Technique"I hate to say this, guys, but I saw the same yellow streak on the Surface 3 that was on display at Best Buy.
You should have given in to your Medical natural instincts and applied the "Amelioration Technique"![]()
Indeed I did; unfortunately there is a high degree of attenuation of the amelioration technique subject to tachyphylaxis. (i.e. it doesn't work after you apply it frequently...)
