Will this power bank(INIU 140W) with USB-C adapter, Power My SP6
The Ionian
So will this power bank with this adapter, run the Surface Pro 6...Thanks,
This is the USB C to USB A adapter...
Wiki on this type of USB C To A adapter in the paragraph, "Surface Connect to USB-C Adapter",
Microsoft Article on using power banks to run SP's...
"If you connect a lower-voltage charger or a USB-A charger with a USB-A-to-USB-C cable, your device may charge slowly or not at all. It won’t use Fast Charging. Please connect a recommended charger instead".
Unfortunately, using a USB-C to USB-A adapter will not work. You'll need to purchase a Surface Connect to USB-C charging cable. With this configuration, you can utilize the 140W C1 charging port to enable Fast Charging of your Surface Pro 6 per the PD 3.1 specification.
There is a decent assortment of Surface Connect to USB-C cables on Amazon that you can choose from.
Thanks...I just got the Surface to USB -C cable and the INUI B64 140 W Battery bank...very impressed...thanks for your help...
