Makes sense -- if it isn't transferring anything there's no speed to rate ;-) Is it the same if you turn off Bluetooth?...16Mbps at idle so it does ramp up under load.
Bluetooth on or off?...a bit concerning. Hopefully will see a patch soon...
It's good you have the safety-net of time to return it. It might be worth considering, maybe revisit the device once they come out with the 2nd-gen version of the SP3.She did tell me I have 45 days to return the SP3. Would rather not as I do like the form factor.
I'm testing it now myself, not sure if the guid are the same but here's the command.
powercfg -setdcvalueindex 381b4222-f694-41f0-9685-ff5bb260df2e 19cbb8fa-5279-450e-9fac-8a3d5fedd0c1 12bbebe6-58d6-4636-95bb-3217ef867c1a 000
Btw, this setting only affects wireless power saving to force it max performance when on dc power which replicates the same setting as ac power mode. Confirm the setting change before and after with 'powercfg /q | more' and it should show on the first page.
