Solved Wifi Direct
It's ironic. I have no grandmas anymore. They left at the time TV was B&W. It's just that in my job I see sooooooooo may (majority) of more than well educated people struggling with not so advanced needs. Many ask for help, some abandon and some just go and buy a new pc. It's just not made for "normal" people. It's made for collecting revenue.
I think the vast majority of people just use their new Surfaces using the defaults, Hyper-V and WiFi Direct File Sharing are both advanced scenarios. Hyper-V really only comes into play for developers, test labs and advanced legacy application compatibility remediation.
OK. As the forum admin you must know better. Please remove the whole thread for lack of interest then.
Sorry for bothering.
Thanks anyway.
I think the thread has value, I'm just questioning the assertion that Hyper-V is a standard consumer configuration...
Sorry for the necro; the internet is bare on this….
Usually, I’d connect "Your Phone" (the Ph. <--> PC connectivity app) on my SP6 to “Link to Windows” on my Galaxy Z Fold 4 via WLAN (Wi-Fi/Wireless LAN);
But ATM, my access points are down, so I want to connect to my Galaxy Z Fold 4 via Wi-Fi Direct.
I’m seeing info that my Surface Pro 6 (AKA SP6) should support Wi-Fi Direct, but upon trying to find/enable, & do the checks to confirm, nothing.
Am I going to have to disable Hyper-V, or is there a way that both are usable?
