Zkyevolved
Well, I got mine! I'll post some pictures and a video of it later after some time with it. It looks chunky on the website, but in all honesty, it isn't as fat as it looks!
			Thanks for posting those temperatures - it really looks like it makes no difference, which is a bit surprising but really good! Subjectively, did it seem as though the fan was operating any more often to maintain those temperatures (although I appreciate that it is very quite and often not noticeable).
Also, is there anything else that you think is particularly good or bad about case? I've been looking for the right one or ages, but every time there is a single major flaw (power cable doesn't plug in, corners aren't protected, etc).
Thanks for taking the time to monitor the temperature. If you could find the time some video review would be great.
I had the incipio feather and capture cases on my SP2 but both of those cases were badly designed and overheated the device.
Daft question, but is that the Incipio Feather or UAG case that is deformed - I was just about to pull the trigger on a UAG when I saw your comment!
I have only heard bad things abut the Incipio cases, but that is the first time someone has suggested that they overheat as well!
