rancidcrab
Noob question:
Do the tuning settings stick at reboot, or do I have to reapply them every reboot?
I played around with the XTU tool all day and got some great results while gaming and office tasks, but no matter what I do, I can't put my SP3 to sleep even with the slightest undervolt applied. Really disappointing :/
I recently tried undervolting using the XTU utility not so much as for performance gain, but to see if I could improve battery life. I got it to a very stable, (read conservative) settings and benchmarks improved by about 12% so I know it’s doing something, but I still haven’t figured out if it’s having any effect on battery life because I can’t seem to get the settings to stick. I don’t know what’s causing the utility revert to default because the setting stick after reboots and initializing from shutdown. Just after some time (a couple of hours?) when I check the utility, it says that the “application exited unexpectedly”, maybe due to platform instability. I’ve done all the stress tests and everything looks all right. I’ve tested minimal numbers (all set to -20mV) and still experience random resets. This utility is not meant to be run at every boot, correct?
This is normal, I don't know what causes it but instead I use Throttlestop, although that only can underfoot the core not the cache & gpu it does not however reboot like XTU. I have gotten a stable underfoot of -92mV. So give it a try, its free anyways![]()
