Surface Tweak Tool for Surface Pro 2 - Release!
Exactly the same, I thought there was subtle but notable differences, cant recall them all OTTOMH now?
But yes I will test soon (time permitting) & give some feedback... BR.
Well they are small differences but they don't/shouldn't affect this tool. The only difference that it affects this tools is the different CPU (Core i3 and i7 models), but the underlying technology is the same, so the drivers should be the same or very close, and that should not affect the tool.
Big thanks! :D
Well it seams that this forum doesn't allow links to the outside anymore.
Which I find it funny, because I using my server to not use theirs... bandwidth is usually costly. But I guess they have incredible offer that they must force people to use theirs. Sure, Ok, more savings on my side! :)
So anyway, here the file again.
The forum guidelines never have allowed links to direct downloads, (staff is exempt). You could link to the page that download was on. So long as it isn't another forum, which also is in the guidelines.
Ah ok very good! :D You could have PMed me a while back about it or be a bit more specific in the edit message. I would have taken action earlier and not cause more work on your side by you guys going through every posts of mine to, essentially, clean up after me, especially that I didn't notice until now you have being doing this. :/ I feel bad now.
I'll prepare a page for this when I have a moment of free time.
I just don't want to use your bandwidth, even though your servers are much faster than mine little web server that I am registered to, I don't think it is fair.
@GoodBytes no reason to feel badly. It just one of the things forum moderators and admins do and this isn't the only forum I do it on. Part of the job. Sorry if I came across as harsh. ;)
Yup, it works now, thanks. By the way, I had this problem on Windows 8.1; I never ran the Windows 10 Preview on my SP3, just on my Desktop.
Yea I think a Windows update screwed the program up.
Glad it is fixed!
So I installed Windows 8.1 back on my Surface Pro 2, and got with the newly release firmware, and my experimental build of Surface Tweak Tool doesn't work anymore. Not because I put Windows 8.1, but that now the Intel Graphics Control Panel executable are gone. So now they didn't disable it, they removed it completely.
Why am I started to think that every time I go a step forward, a Microsoft employee is watching this thread and releases a patch to the Intel drivers to block me.
