bosamar
It's a touchscreen LCD monitor, 23". Designed for Windows 8 and supports 10 finger gestures.
I'll check it out. Thanks.
Another option instead of getting a touchscreen monitor, is a touchpad, just in case you don't want fingerprints all over your main display. This Logitech T650 touchpadI'm keeping my RT and my two desktops both have Pro on them. I may update my primary desktop to a touch screen.
has gotten good reviews.
But the wedge mouse won't replace a touchscreen monitor.Or the wedge mouse![]()
But the wedge mouse won't replace a touchscreen monitor.![]()
My bad then - I thought it was just a touch mouse and didn't offer gesture control.It is supposed to, at least as much as a touch pad anyway. Move the mouse to navigate and touch the mouse for gestures, 4 way scrolling and swipes in from the bezel in all directions. I haven't used one yet but they are supposed to be great for the Windows 8 interface.
Hey guys im curious to ask if any of you have the surface RT and are getting the PRO?
I currently have a 32GB + 64 SD in mine and i plan on also getting the Pro![]()
