leeshor
My guess is that TH2 will be released to everyone before the end of the first 2 weeks of November. It will probably corect 99% of the issues people are seeing now. It may be a game changer.
I agree with you I like things to work.
OP - have you installed all of the updates and firmware updates? What are you using for A/V? What type of router are you using? Are you on 2.4GHz Wireless or 5GHz? Are you using Bluetooth while on 2.4GHz?
We could help given enough info....
Really that is crazy but I guess I am just got unluckyThat's why i bought a surfacemy ipad didn't work straight out of the box, couldn't even get past the setup before it bricked.
Comcast DNS is infamous for issues relating to websites no loading from Windows 8.x - 10 clients - I switch DNS providers to get around it at home...I installed all updates from the check for updates. Then I called Microsoft agent and they had me re install the modem driver...I am using a router/modem from xfinity. I use 5ghz because it is a Ac compatible router so I put all my devices if they run Ac on 5 ghz then all others on 2.4. My Bluetooth is on because I use the pen a lot. Maybe I received a bad one
