Please try these patch for your :I have tried everything from disabling standby, tried the fix earlier in the thread about deleting the batteries from device manager and running down and letting sit for 10 hours. Nothing worked. I never had mine set to completely 'shut down' only had my SP6 hibernate when I hit the power or closed the lid and the same issue happened. It didn't matter whether it was 1 min or 2 hours. It always came back up with 75% or 73% power. There is no way an app can drain the battery that fast so it is def a software issue. However it did take the normal time to charge back up, but again it has to be a software issue. One thing that DID work as a workaround for me was moving everything to sleep. I.e. Hitting the power button and closing the lid is now set to 'sleep'. This does a slight battery drain when it is off for a while but no where near 25% that we are seeing in this thread. If someone has a link to a new firmware patch that fixes it, please post as the only one I am seeing is the Sept 6th on the MS site and that didn't work. Thanks all
Microsoft Update Catalog
