Surface Pro 4 Charger not working
ArcticPyro
I am having an issue with my charger, it is not charging my Surface at all. The light only turns on for a second and that is when it is plugged into the wall.
Same thing goes for the USB on the power supply. It only charges my phone for a second then stops.
Any help would be appreciated.
Welcome to the forum
You have a couple options:
Go to a Microsoft Store if you can and they may swap it.
Call Microsoft and try to get them to send you a replacement. If under warranty they should.
Get on Amazon and order a new one.
